Winter tires
Old 10-02-2006 | 12:19 AM
Mavrick
Default Winter tires
Hi guys,
Just wondering if I could use 195/55R15 tires on the 2006 Accord DX (Canadian version)? The stock is 16 inch in diameter.
Thanks for your help.
Old 10-02-2006 | 12:35 AM
Default RE: Winter tires
Hi Maverick..
In answer to your question, the tires that are stock on 2006 Accords are 195/65/15 , so you must have a up graded rim on there already and if its a 16" you will have to buy 15 " rims to put on your 15" tires...
Old 10-02-2006 | 12:48 AM
Mavrick
Thanks for the reply.
I havent gotten the car yet, but Honda indicates that the stock tires are P205/60R16. Since I already have a set of brand new winter tires sized 195/55R15, I would get 15" inch rims to put them on, as you mentioned, and fit them on the new Accord. Will it cause any problems for the suspension, the accuracy of the speedometer, etc.?
Thanks.
Old 10-02-2006 | 01:01 AM
No Sir, it wont change anthing of any significance with the 15" tire and wheel set-up.
WheelBrokerAng[sm=americanasmiley.gif]
Old 10-09-2006 | 01:20 AM
Outside tread diameter is different. Your speedo will read 9% high. I don't know for sure, but brake clearance is probably OK. The smaller tires give you less ground clearance, which probably isn't good in the snow.
205/60-16 = 25.6" diameter
195/55-15 = 23.4"
Different models carry different tire sizes. My 2003 Accord has 205/65-15 tires, while the DX Accord came with 195/65-15. The V-6 of that same year had 16" tires.
Old 10-09-2006 | 03:24 AM
YeuEmMaiMai's Avatar
you can use those tires only after you get a 15" rims to mount them on. You can use the 15" rims from a 1998+ accord that has 5 lugs (V6 for 1998-02)
elessar78
07-11-2008 12:51 PM
willowtreexx
01-13-2008 11:11 PM
custy
11-17-2007 12:05 AM
lfeng2002
09-09-2007 05:55 AM
pyaarawala
08-26-2007 08:11 PM
Quick Reply: Winter tires
