Won' t go past 3 grand
Old 10-20-2010 | 11:31 PM
Mdschmidt's Avatar
Default Won' t go past 3 grand
Ok so I just swapped out my f22 non-vtec for an h22 I have everything done but when I start the car I have a cel and the car won't go past 3500-4000 Rpms it's like I'm hitting the rev limiter and when I let off the gas and the Rpms drop back down the car seems to want to die out. Any suggestions?
Old 10-21-2010 | 12:53 AM
Have you checked for codes?
Old 10-21-2010 | 01:33 AM
Mdschmidt's Avatar
I'm not really sure how to do the jumper wire to make the light blink
Old 10-21-2010 | 03:55 AM
It is pretty simple.
I have a couple of questions though. What wire harness did you use and what ECU are you using?
If the current ECU is set up like the accord's then all you need is a piece of wire or a thin paperclip to short the blue two pin connector under the glove box. Turn the key to the II position. Count the Check engine light flashes. Long blink=10, short=1. So LLLS=41.
See this site for images: dhost.info/accordinfo/howto/cel.html
Old 10-21-2010 | 10:39 AM
Mdschmidt's Avatar
I reused the accord harness I just had to de-pin 2 connectors and use the h22 ones and lengthen the oil pressure sending unit wire I found a guide for it online. And as far as ecu I'm using a non-vtec accord ecu until I can get a P13. And vtec isn't hooked up
Old 10-21-2010 | 02:09 PM
You can follow the instructions on that site I referenced above.
Old 10-24-2010 | 11:34 PM
Mdschmidt's Avatar
i got a code 16 fuel injector, i checked the plug and the rubber seal got in the way and wasnt making a good connection so i fixed that and it runs fine, but now i keep blowing the ECU fuse any ideas?
Cody_754
03-08-2024 11:34 AM
argarcia86
03-17-2013 09:28 PM
Slidesquad240
09-29-2012 10:29 AM
sofireguy
07-07-2009 02:32 PM
pfrathjr
02-10-2008 06:51 PM
