XM Radio Antenna routing for 2003 EX
Old 01-05-2007 | 07:59 PM
mumbly2003
Default XM Radio Antenna routing for 2003 EX
I received an XM radio for Christmas and I'm trying to determine the best way to route the antenna wire on my 2003 Accord V6 EX. I'm pretty sure I want to go out the back through the trunk, but I don't know how I should route the wire from the front of the car to the back. Is there an existing cable tray of some kind that I can follow, should I just go under the floorboard carpeting, can I go under the side door molding, etc.? In any case I think I'm going to have to pull out the backseat, how is this done? I'm hesitant to just start pulling on things that I don't know how are installed for fear of doing more damage than it's worth.
Any advice or information would be greatly appreciated.
Thanks,
Marc
Old 01-05-2007 | 10:12 PM
sir_nasty's Avatar
Default RE: XM Radio Antenna routing for 2003 EX
Personally I'd just run it along either the passenger or drivers side and tuck it between the carpet and the trim, that's what I did with my antenna on my 94 accord anyway.... then you can run alongside the rear seat and not have to remove it....
phil2415
08-15-2013 07:13 AM
scoostraw
06-13-2013 07:52 PM
b|@ck-0n-b|@ck
08-14-2010 09:48 AM
08fxdf
07-26-2010 06:23 PM
ohanahorse
09-15-2009 11:38 AM
