HAF Help & Suggestion Center Need help with HAF? Ask. Have a suggestion to better HAF? Tell us here.
no speedo
Old 01-15-2008 | 10:56 PM
9accord5's Avatar
Default no speedo
my speedo works every now and then and when its not working it stays at 20...what do i need to replace?
Old 01-15-2008 | 11:09 PM
smaglik's Avatar
Default RE: no speedo
sounds like the speedo head. my 94 did that. you can either send it off to a speedo repair place (no swimsuit jokes, please), or get a new one....
Old 01-15-2008 | 11:13 PM
9accord5's Avatar
thanks for the reply, and where do i find one of them?...and a buddy of mine said it could be the vehicle speed sensor? is that a possibility also?
Old 01-15-2008 | 11:27 PM
9accord5's Avatar
wow, i just realized this is site help...im an idiot. anyway it can be moved to get more traffic?
Old 01-15-2008 | 11:34 PM
smaglik's Avatar
i would guess its not the vss, cause your symptoms are identical to mine, but i beleive that if the cruise still works, its not the vss....but dont quote me on that.
Old 01-16-2008 | 09:03 AM
9accord5's Avatar
The cruise only works if the speedo does.
Old 01-17-2008 | 02:25 PM
smaglik's Avatar
i'd stll guess the speedo. anyone else?
Old 01-17-2008 | 02:49 PM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: 9accord5
It's the VSS. You are lucky.
Cruise doesn't work when speedo doesn't work = VSS problem.
Cruise works even when speedo is not working = speedo problem. On mine the cruise works even when the speedo doesn't, which means there is something wrong internaly with the speedo. That means I have to pull the speedo and send it to a speedo shop.
Old 01-17-2008 | 06:18 PM
9accord5's Avatar
oh, alright cool thanks guys.
Old 01-17-2008 | 06:24 PM
9accord5's Avatar
i found em on ebay, do i need the one with the sensor andgear? or the just the sensor?
Quick Reply: no speedo
