air breather?
RE: air breather?
not sure if they even use it on FI cars but on carburated cars it was from PCV valve routed back to the air cleaner housing where a filter was attached to catch the oil... used to have to change them every time you chanced your air filter (about 1 time a year in my case). On the FI cars they just route the PCV valve back into the intake tube
RE: air breather?
yeah, that is what goes on the valve cover for the tube that goes to the intake you wont see any real gains from using it, if anything its a little less efficent to use it cause you arent reusing any of the extra gasses
and depending on the accord you have that tube is joined with a coolant tube as well...... well i think it might be most accords
