Cold Air Intake Question
Old 03-20-2006 | 01:03 AM
lukpoiwai's Avatar
Default Cold Air Intake Question
Hi,
I got an AEm Cold Air Intake System for my Honda Accord 1993 Coupe. This change has made a considerable improvement and boost on my car's performance.
I was told by my mechanic that this cold air intake systems would work at its optimum level if it draws in cold air. If you have been using your car for sometime and the engine gets hot inside, chances are, your cold air intake won't be doing its job.
He further claims that, I should put an insulation to cover the entire aem cold air intake system to protect it from heat hence it will draw cold air all the time. Is this true or a misconception on his part?
Any reply would be appreciated. Thank you very much.
Kind regards,
Luke
Old 03-20-2006 | 02:12 AM
mbo1985's Avatar
Default RE: Cold Air Intake Question
Well if it's not sucking in cold air, then you will be losing HP. Cold air is more dense, thus your engine is essentially getting more air when it's cold then if the air was hot.
And he's right about the heat wrap. Although you may not notice a difference, theoretically, the cooler you can keep the air the more power you can make. Now will you even notice a difference with the wrap? I doubt it. As long as your cold air intake takes air outside the engine compartment, then you shouldn't worry too much about the engine bay heat.
I have seen one civic with a tiny hood scoop (or ram air) type deal that was placed right where his CAI was. I am looking for something like this for my accord. Has anybody seen anything like this?
Old 03-20-2006 | 03:17 AM
lightshow's Avatar
the mechanic is so right...in a real world situation...the metal tube on your aem gets so hot that the air coming in gets extremely heated up making you loose horsepower....wrap that thing up and youll notice it
Old 03-20-2006 | 09:56 AM
lukpoiwai's Avatar
Thanks a lot kind folks for the reply and opinion on this.
Incidentally, where can I buy this kind of wrap just to be on the safe side? And what is it called?
Thanks in advance.
Kind regards,
Luke
Old 03-20-2006 | 02:51 PM
mbo1985's Avatar
jegs.com is where i get all that miscellaneous sort of stuff. They should have some intake heat wrap. I've seen it at pep boys too.
Old 03-20-2006 | 09:54 PM
marbro's Avatar
its also refered to as thermal wrap
Old 08-27-2006 | 05:23 PM
hondaaccord02
Hey i have a 2002 honda accord
last winter i put a magnaflow performance exhaust and i was woundering if anyone know if an AEM cold air intake would go good with my exhaust system
Booba860
02-01-2010 09:54 AM
petef23a
12-14-2009 09:23 AM
SCEPTOR98
10-15-2008 09:40 AM
saintslil23
04-21-2008 10:12 AM
94coupeaccord
04-12-2007 12:00 AM
