exhaust install
Old 06-15-2007 | 11:55 AM
greenguy77
Default exhaust install
Alright guys, so I made up my mind on my next mod...the Apexi WS2 exhaust. But before I get it, I wanted to know some stuff about installing it. Iread the hardest part is getting the old exhaust off, but what do I need to know about putting the new one on? is it just bolts? Also, am I gonna need a lift for this? Im on a tight budget and I really dont want to pay a mechanic if I can do this just by myself and a couple other friends. Thanks in advance guys.
Old 06-15-2007 | 01:19 PM
pyaarawala's Avatar
Default RE: exhaust install
If you have a junkyard near you, you can get it done for cheap there. I got my entire catback system redone with aftermarket products all for $100.
If you still want to do it yourself, then yes, a lift is VERY helpful compared to a jack (lift gives you more room to work, especially since you'll need to chainsaw your old piping off). You'll also need to weld pipes together, weld flanges and hangars on, and also have a machine to bend the piping here and there. It is a lot of work and you're better off getting it done, but it's definitely possible.
As for a torch, the only time I saw the one who did my exhaust use it was to get the old O2 sensor off my factory catalytic converter.
Old 06-15-2007 | 01:28 PM
ghostleg
yeah im gonna have to side with pyaa on this one. it is very capable for you to do, but to make sure its on correctly you should find somewhere to get it done. a junkyard will weld it for you, if not, try a local machine shop. thats what i did on my last car. i asked if they could make a simple weld for me, they said no problem and charged me $35 buck then i just bolted the rest of the catback on and called it an exhaust
Old 06-15-2007 | 03:45 PM
BlkCurrantKord's Avatar
It's just bolts. I did mine in my driveway in an hour.
Old 06-15-2007 | 09:54 PM
pyaarawala's Avatar
ORIGINAL: BlkCurrantKord
You make it sound so easy. I'm assuming you welded the hangars yourself?
Old 06-16-2007 | 06:23 PM
Dazed's Avatar
It does sound pretty hard. For the first time, most of the replies werent: Its easy, just read the instructions.
I didnt think it was tht hard either. Welding, hangars, i dont own any of those tools, except for my clothes hangar lol.
Old 06-16-2007 | 11:47 PM
KevinAccord's Avatar
it's not hard... just bolt on. if u need to weld somethng a muffler shop will do it is a few secs... not expensive actually 20-40 bucks...
Old 06-19-2007 | 09:37 AM
greenguy77
Hmmm...so half of you say its hard, and half say its easy....looks like Im gonna have to do some thinkin about this one, lol.
Old 06-19-2007 | 10:39 AM
ORIGINAL: pyaarawala
Didn't have to weld anything. Remove old exhaust, install new. 3 bolts to the cat, 2 for the mid section, 2 for the rear.
murphyje
06-01-2011 06:48 PM
deadaccord92
11-17-2010 10:05 PM
accords own
08-13-2007 05:22 AM
poser_pilot6
11-24-2006 10:31 PM
HondaLawgik
05-03-2006 02:32 AM
Quick Reply: exhaust install
