Need a lil CAI advice
Old 01-31-2008 | 11:07 PM
kingpin
Default Need a lil CAI advice
On my old car I had a AEM CAIwhich I loved and made quite a difference from stock. I never had any problems with water getting in it.
Now I have a 92 Honda accord and it sits lower at the stock suspension height than my other car.
I want to clean up my engine bay and was thinking of getting a AEM CAI on this car. I am kinda leery thou because it sits so low already.
Anybody have any input or advice about water getting in it?
BTW I am not really going for performance so much but to make some room under the hood.
Old 01-31-2008 | 11:34 PM
accords own's Avatar
Default RE: Need a lil CAI advice
if you live in a wet area, then just make sure to get a bypass valve for your intake and you will be protected from hydrolock. and the only way you are gonna get hydrolock is if your intake is completely submerged in water.
Old 02-01-2008 | 09:13 AM
klrspz's Avatar
right... also, unless you have a v6 (nothing you've said or in your sig implies anything however) you should look into an eBay CAI... it's just a pipe really with a filter.. just get an ebay pipe and a K&N or other performance filter..
see this: http://hondaaccord.wikidot.com/intake-info
Old 02-01-2008 | 11:03 AM
sir_nasty's Avatar
since you're not worried about gains just order a SRI off ebay, the filter will take up a little extra room in the engine bay vs. a CAI however you don't have to worry about water.
Old 02-01-2008 | 06:21 PM
kingpin
Yea I want to take the filter box out the picture, or at least slim it down some. That's why I don't want a SRI. I want to do some plexi work there over the intake pipe. I will take a look at some eBay pipes. Thanks for the tips
Old 02-01-2008 | 06:26 PM
sir_nasty's Avatar
even with an sri you won't need the box just the filter will be in there, if you need more room than that then get the bomz cai with an aem bypass valve.
Old 03-02-2008 | 02:45 PM
ieetgluu's Avatar
I would NOT suggest eBay intakes if you can afford something better. Reason being is that an intake such as an AEM will be made to fit, require no rigging of any sort, andshouldsupply you with everything you need to convert from an OEM to an aftermarket system. Ive had several experiences with both "eBay intakes" and AEM brand intakes. Both can/will work, but a good brand will be made the best and will be less, if any hassle, trust me. So if you can spare the coin, get somethin decent. Something used maybe with a new filter would be a cheaper alternative. And I wouldn't suggest cheap filters either as they often have a metal mesh on them that will rust, atleast in my experience. K&N and AEM Dryflows are nice. Hope this helps.
Old 03-02-2008 | 02:49 PM
ieetgluu's Avatar
And if the space taken by a bypass is a concern, Ididnt have one on my AEM V2 for 2 years and had no problems. I stayed out of puddles for the most part on the filter side of the car.
Old 03-02-2008 | 03:03 PM
03Sleeper's Avatar
Don't worry about hydrolock...you would need to drive in at least 3 feet of water...come to a complete stop...wait for a few minutes...then drive off.
I trust you are not that ignorant in your car handling skills.
aperson9923
07-11-2012 01:49 AM
DA KID RYU
01-28-2009 11:29 AM
02accV6
06-21-2007 09:55 PM
charliejo6443
02-27-2007 08:45 PM
xxxcoojaxxx
07-01-2006 08:49 PM
Quick Reply: Need a lil CAI advice
