New throttle body, help please
Old 11-07-2012 | 12:51 PM
Accord97's Avatar
Default New throttle body, help please
I have a 97 honda accord, its an automatic and im having trouble finding a bigger throttle body for it. I recently bought a blackworks racing throttle body but it didnt work because i have two throttle cables and it only had the one switch for one cable. I think the reason i have two cables is because its an automatic. Does anyone know where i can order a new throttle body for an automatic transmission or if they even make one?
please help me out if you can, thanks.
1997 Accord f22b1
Old 11-07-2012 | 12:52 PM
shipo's Avatar
I'm curious; why do you need a larger throttle body?
Old 11-07-2012 | 01:19 PM
Accord97's Avatar
Because with a larger throttle body it will help increase horsepower, allow more air in and help increase throttle response.
Old 11-07-2012 | 02:27 PM
shipo's Avatar
Really? Call me a skeptic, but my bet is that a larger throttle body won't do anything to improve the output of your engine.
Old 11-07-2012 | 02:51 PM
Accord97's Avatar
Oh really? i thought it would help out. how come you say it wont do anything cause i dont wont to get it if it wont do anything to help?
Old 11-07-2012 | 03:59 PM
shipo's Avatar
Unless you change your cam(s), the exhaust, the upstream intake plumbing, and the intake plenum to increase the overall systemic capabilities of your engine (changes which will give you extra high RPM power but will most likely reduce your midrange torque by a very noticable amount) then the single addition of a larger throttle body won't do diddly for the engine.
Old 11-07-2012 | 05:02 PM
Using low-restriction intake components, like air filter, short-ram intake, etc. can only improve things to the extent that the stock stuff is restrictive. Traditionally, Honda 4-cyl engines don't have very restrictive stuff so it won't improve as much as it would for some other car companies.
Old 11-07-2012 | 07:45 PM
Accord97's Avatar
Oh i didnt know that but it does make sense, so then my stock throttle body should work just fine or better then a bigger one?
Old 11-07-2012 | 08:19 PM
shipo's Avatar
Yup, you're most likely better off with the factory throttle body.
ghostpilot
03-04-2012 01:17 PM
Al_S
06-26-2010 09:17 PM
johnnym
07-13-2009 09:11 AM
kissbally78
01-14-2009 09:14 PM
TedsF23accord
05-30-2006 02:30 AM
