2001 accord exv6 can i tie my low fuel wire into my fuel gauge wire to get light?
hello I diagnosed my fuel gauge sender to be bad my low fuel light does not come on. tried to change it but the 8 screws are rusted on there solid and its not worth all the trouble to go thru that and possibly damage the tank. my question is If I jump the fuel gauge wire into the low fuel wire (lt.green/red) will it read when there is low fuel and turn the light on? any input would be appreciated thanks guys.
ty for the response that was exactly what I wanted to know. no the light does not come on im trying to get it to work lol. its my fuel sender but I cant get my tank open easily and im not gonna go thru hell for a low fuel light. hey if I tap a temp gauge sender into my radiator hose and ran it to my temp gauge you think that would work?
not to confuse you its 2 different problems I have. I have a thread about the temp gauge problem I have if you are interested in breezing thru it and giving your input on it I would appreciate your time. thanks bro
The temp gauge is mainly for the driver for a warning as to when it goes from "normal" to either too hot (like a stuck closed T-stat) or too cold (stuck open T-stat), or for that matter a complete loss of coolant. Short of fully testing the wiring from the gauge cluster to the sender, I really don't know what to do, other than maybe add another sensor and a gauge for it. I'm not sure if the wiring actually goes thru the ECU or not, as some cars do, and some don't. In the old days, guys would pull a plug out of the cylinder head and put a mechanical sensor in place so they could get an actual reading, versus depending on an idiot light. Now companies are offering electric temp gauge set ups (mostly for Hot Rodders) to do that. Summit Racing even offers a metal splice for your hose that has a bung in it for a temp sensor, in case you don't have a port in the radiator or cylinder head.
Personally I'd test it according to the FSM, and see if your results equal that of the FSM. Then I'd ohm meter the wiring from the gauge cluster plug in connector to the sender, and see if I had an open (break) in the wiring. After that (if everything is OK, I'd probably replace the sender. If I still had an issue, then I'd look into getting another gauge cluster (thinking I had a bad gauge). Basically verifying the wiring as good first, then a good sensor followed by a good gauge. Most of them have a very small electric motor inside that might have died.
