New abs sensor not working
hi there,
I just replaced front bearings in 2004 Accord. Manual tranny. While I was doing so, I broke the abs sensors. I had to drill them out and then replace them. After putting car back together and test driving my abs would engage at over 5 mph. It was pulsing so fast that it almost sounded like grinding and Lmost completely prohibited me from stopping. Slow speeds, less than 5 mph, works fine. After a few tries, ABS light came on and brakes worked normal except now ABS won’t engage and I skid. **** car off for a few minutes, light goes off and same thing happens all over again. Any suggestions? Maybe sensor got dirty?
hi there,
I took sensors out nd cleaned them. For a moment the brakes worked fine. Then the ABS kicked in again any time I braked. The ABS light came on disengaging the ABS. Now I cannot get light to go out. My code reader reads no codes. I used a multi meter in sensors and got approximately 1.4. Any suggestions?
https://honda-tech.com/forums/honda-...aring-3131185/
Basically it sounds like the wheel bearing was installed backwards. Check to see if a metal paper clip is magnetic on the side of the bearing closest to the ABS sensor or the opposite side. The magnetic portion of the bearing should be closest to the ABS sensor. A basic ODBII Reader won't be able to read some of the more advanced errors. You'll need one that will support Honda brakes/ABS.
Worse now
Ok....so i took apart both sides again. I cleaned off any residual metal dust that was on the bearing from when I reemed out the hole to put the ABS sensor back in. I also checked to see if the bearing was magnetic on the inside and it was. My ABS light is still on but my brakes work just fine. I took it about 50 miles and now the brake light and ABS lights are both on. I’m scared to drive it now. My home code reader and the one T the auto parts store were both unable to reset the codes. I’m afraid I’ll now have to take it to a dealer. Any more suggestions?
93Accord2.2
11-07-2013 07:10 AM
