New Here 97SE (few questions)
New here and Just Checking in. I just bought a daily driver 97 Special Edition 4dr. 4 cylander, its Heather Mist Metallic, in mint condition. Automatic with 63k on the clock. all it needed was a radiator. The only reason i call it my daily driver is because it will not be getting as much attention as my 03 s2000!
On a side note, the car has a bit of a rough vibration when in gear at a stop. the plugs are NGK and tune up stuff is all brand new as well. is there a remedy for this problem? if i bring the idle up to 600rpm it goes away, the car normally idles at 400rpm (is this too low?)
my throttle cable is stripped on the threads where it attaches to the bracket, so i cant even take up the slack in the line that much either.
and lastly, my trunk release cable inside the car is getting jammed up somewhere. the previous owner said he had it changed out but the same problem came back. right now i have it disconnected. any ideas?
Thanks for listening to my problems. ill try to get pictures up later today or this evening. see everybody around!
Cody Is Cool
06-01-2007 01:53 PM
