New member, also need advice on build!!!
So I just bought a 98 Accord sedan ex with the VTEC 2.3l it also came with a bunch of parts the main being a Brand new HEAD with port polish, valve job , and a new something I have the receipt you can kinda make it out New intercooler plus some red fans it comes with a spare 2.3l block ? None of the parts are installed so I was wondering what I could do ? Any and all replies helpful.
Yeah, he was going to turbo it and was just waiting to piece everything together before it went in .
Welcome to the forums. Did he include low compression pistons with the block? If not, I'd sell off the intercooler, and build a NA engine to have as a spare. These 2.3L are good motors that will do over 300K miles.
Nah the block is still stock from when he pulled it, what kind of power levels you think I can get with a N/a build I already was shopping around for the pistons & con rods I think Eagle or from wiesco. is the stock IM good enough cause I couldn’t find any for this car also it’s a 5 spd with stage3 clutch
As for the Intake Manifold, you probably won't find anything that flows better than stock, as that engine was already optimized by the factory, and nobody makes hot rod parts for it in this country. Even turbo cars are using the stock intake manifold (at least those few I've seen). Keep in mind most people either go with a V6 (and do a trans swap), or swap to an H series, as parts are more readily available for them (the H series).
I hope this helps.
streetlimitz89
07-04-2013 05:24 PM
mass-accord
07-30-2011 07:01 PM
chrishoangz
12-11-2007 12:15 AM
