Oil Additive
Oil Additive
Good morning,
I have a 2010 Accord Coupe 4 cylinder, with about 315k miles. I recently noticed a leak. Due to the miles on the car, I do not want to spend a lot of money to fix it, so I was considering using an oil additive. Is that something I should do, and if so, what kind should I use? I currently run synthetic oil, and I change it when the indicator gets to 20%.
Thank you!
Michele
Thank you!
Michele
Good morning,
Thank you!
Michele
Thank you!
Michele
Oil additives are generally a waste of money. In your shoes I'd run a "High Mileage" synthetic oil, they have special additives to coax seals to swell a bit to help oil leakage control. Beyond that I'd simply keep the oil topped off; oil is cheap. I assume with the kind of mileage you're putting on your car, which is nearly twice the mileage I have on my 2006, you're shooting for maybe 400,000 before you retire it.
Thank you!
