warning light
warning light
hey guys i have a 1991 accord and an amber warning light has come on, on the dash, its a picture of an engine. Any ideas what it means? i have no user manual. temp gauge is fine and the oil light did not come on.
Thanks for any assistance.
Ecu
What i have found so far is the ECU has found an engine fault. It could just be a faulty sensor or i need to get the code checked to determine which system is in need of repair. I wonder are there any honest mechanics in Sydney.....highly unlikely.
Hi Member...
Find your local Large Chain Type parts store there and call them up to see if they pull codes for free there..
Thank You for joining our forums...Stick around and join in!
Welcome!
Most parts stores around here can only read OBD-2 cars, which means 1996 & newer. Look in the General Tech or DIY sections for instructions on earlier cars. You can read them by watching the flashing light & counting the flashes. Earliest ones have a flashing LED on the computer itself. Later ones flash the yellow check-engine lamp. They switched over right about 1990 or 91 or so.
dmjole
08-21-2012 06:02 PM
