boost problem
Old 07-20-2007 | 04:11 PM
KevinAccord's Avatar
Default boost problem
hey guys, well, my car is turbo now but i have a prob... the car wont go higher than 3300rpm, and it's because itneeds more gas, im new to Apexi Neo and im still trying to fix it and addd more gas, i think i know what to do now but still haven't done it yet....does anyone know what type if sensor does my car has? Hot Wire, pressure, karman? that's all i need to end the set up... thanks guys!
Old 07-20-2007 | 08:50 PM
BlkCurrantKord's Avatar
Default RE: boost problem
Sensor for what.
Old 07-20-2007 | 09:00 PM
Shadow1992's Avatar
Could be you have too small of injectors or your fuel pump flows too little.
Old 07-24-2007 | 05:31 PM
my injectors are 450cc eclipse injectors and my fuel pump is a walbro fuel pump... that's definetly not the problem..... what else shadow1992?
Old 09-05-2007 | 09:50 AM
deathcrow's Avatar
U need to tune ur neo on dyno.Then u know why.
Old 09-05-2007 | 11:11 AM
falkore24's Avatar
The Apexi can kill your engine if you screw with it too much. Get it dyno'd! Also make sure that your wastegate is working properly.
Old 09-07-2007 | 12:34 AM
oh, ok... i will, im not using my car right now bcause of that reason... will post back as soon as i come back from the dyno!
leadfoot
22
09-07-2007 01:50 PM
95bentleyLX
04-12-2007 12:18 AM
HuYnHness
01-10-2007 02:48 AM
blackpearlv6
06-20-2006 11:49 AM
ThePappy
04-21-2006 06:46 AM
Quick Reply: boost problem
