CT Engineering Supercharged J30A4?
After a full night of insomnia, I somehow came across videos of supercharged 7th generation Accords. Some people are doing TL swaps with the supercharger while others are using the stock engine. Well, as you know, the 03-05 Accord V6 has the J30A4 engine, and I don't see that specific year range on CT Engineering's site (Just Google CT Engineering.) I know that the 00-02 Accord V6 uses the J30A1 engine, and so I've heard that the only difference between the two engines is that the J30A4 uses a three-way VTEC system , higher compression ratio, and the exhaust manifold is a part of the cylinder head and not easily replaceable. So, is it possible to install the 00-02 CT Engineering (Comptech) supercharger on my '03 V6, or do I need to use a different supercharger? If so, what model? Thanks in advance.
j30a4
Hi there I am planning on supercharging my 03 v6 accord as well and from what i have read the 3rd gen 3.2 Acura TL supercharger is a direct fit to the 7th gen 3.0 v6 accord. check out this link it has a lot of useful info http://www.cardomain.com/ride/2670346
there are a couple of custom things that need to be done like possibly a custom radiator the upper hose is kinda in the way.
AUTO Design
20
05-07-2015 01:15 AM
