Engine management for f23
RE: Engine management for f23
greddy e-manage or aem ems if you have a manual you can drop in an odb1 ecu and do the rechipping yourself with chrome, uberdata, i think theres one or two other programs as well
I gotthe1st version of theEmanage... I woulda chosen something if I knew what I was buying... I wouldnt recommend what I have... It works but others are better... AEM EMS is expensive but probably one of the best out there... But again,,, Unless your Fully Built that AEM EMS wouldnt be worth its value to you. IMO
Thanks for your input guys! I am automatic and on a budget but i will save for something that is reliable. I heard my ecu cant be used with hondata. Can someone explain that to me?
ORIGINAL: kris.h1987
You can use a chipped P28 and and rewire your car to make it OBD1. It's not as hard as it sounds.
Just saw that you have an auto. You'd have to swap to manual or find the appropriate TCU to swap to OBD1. You're better off staying OBD2 and using E-manage or AEM FI/C
x2 on not chipping it yourself. P72/75 will work with auto TCUs, but save yourself the headache of chipping an Accord, especially an automatic one, especially an OBDII one. Even if you did successfully get it chipped, there is little to no support out there for them and your gonna be dumping tons of money getting a basemap and tune at a shop.
ORIGINAL: BlkCurrantKord
Cool I think i just might do that. Any idea on the cost?
