F23A Turbo question. how much boost?
Old 05-15-2008 | 03:13 PM
SKHEMR's Avatar
Default RE: F23A Turbo question. how much boost?
I have crower conn rods, cost me $750. Go with Eagle Rods for about $400.
Aries pistons $650 custom made 87.5mm. Go with J.E. or CP piston. Aries are a little noisy.
The crankshaft can support 600hp
I still can't find a cam shaft but the stock is ok.
I can't remember what type of valves & springsI have.
Old 05-15-2008 | 03:17 PM
SKHEMR's Avatar
Myhonda has been parked so long because I drive the S14 more. Until it broke down. (Spun a main bearing and I need another crankshaft). The turbo power onthe 240is so much smoother, where the honda has a bit of turbo lag.
Old 05-15-2008 | 03:49 PM
KevinAccord's Avatar
thanx man! what's the S14 HP? and theAccords?
Old 05-15-2008 | 05:05 PM
SKHEMR's Avatar
S14 @12.5 boost felt about 240hp, the maf sensor stock is only good for 250. I will about to add bigger injector and a 300zx maf sensor and try to get 280 until the spun bearing thing happen. So I never got it dyno'd.
The Accord was at 238whp and 267 torque @9lbs of boost. I was shooting for 300. But when the vtec kicks in it goes from 140 to 238hp and you can feel it. So I was happy.
Old 05-16-2008 | 12:20 PM
cooooool!!!!! so, @ what rpm does your vtec open? im trying to see which rpm works best for me....(to engage vtec)
Old 05-16-2008 | 05:54 PM
SKHEMR's Avatar
3600rpm
  #17
Old 05-23-2008 | 12:27 PM
thanxs dude... mine was at 3900.... gonna try that one... and it stops @ 3500 right?
  #18
Old 10-20-2009 | 07:59 PM
boosted cb7
Default hey i need help
can you tell me if someone sells stuff to build a f23a for boost like head studs,gaskets,pistons,rods and more
  #19
Old 10-27-2009 | 12:08 PM
depends on where you live... where will that be?
  #20
Old 11-06-2009 | 11:28 PM
vSICK02
angelillo98
04-13-2015 01:00 AM
streetlimitz89
01-28-2013 12:50 AM
gio23
04-24-2011 09:22 AM
micra
08-08-2010 07:19 AM
sUbLiMe96
17
10-31-2008 12:53 PM
Quick Reply: F23A Turbo question. how much boost?
