how much boost will a std f20z1 take?
around 8lbs. is what you want to run on sock internals. IF you want to lower your c/r you need to get pistons with lower c/r ratio.
Do you have $500-600+ to spend on lowering your car??..if not stay stock.
thicker head gasket with lower your c/r a bit. I see the b series guys taking a 3 layer OEM head gasket and drill out the rivets and make it to a single layer head gasket to help with the c/r. My boy just did it on his b17gsr.
angelillo98
04-13-2015 01:00 AM
DREW9555
19
11-06-2009 11:28 PM
