need help
Old 08-01-2010 | 10:04 PM
89accord123438's Avatar
Exclamation need help
hello my name is bobby i have a 89 honda accord hatchback 4 cilender 2.0 i have recitly added some subs and amp and stuff but under the hood i have added a cold air intake and exhaust and im wanting to put a turbo but i talked to my big bro and he told me to vizit here i need some help tell me wat to do and add to my motor to be able to run a turbo in it im wanting to be able to have atleast 10 pounds of boost plezzzzz help!!! thank u have a nice one
Old 08-01-2010 | 10:13 PM
Exclamation some one help
i have a 89 accord hatchback 4 cilender 2.0 i hae recintly added a cold air intake and exhaust i want to put a turbo but i need to know wat to put under neath the hood some one help just tell me want i nee to get and what to do thaxs
Old 08-01-2010 | 10:26 PM
g22cd5's Avatar
Supper Moderator
was the 89 carb or fuel injected? 10lbs might be pushin it on that old of a engine. How many milles? Is it a 5speed or auto?
Old 08-01-2010 | 10:27 PM
g22cd5's Avatar
Supper Moderator
welcome and enjoy your stay. Got lots of good info...its just a search away
Old 08-02-2010 | 12:11 AM
Thanks For joining the HAf..I will move this to the correct forum for you..so do watch that you post in the correct forum or one that relates to your questions..
Old 08-02-2010 | 02:13 PM
yes it is fuel injection and its a 5 speeed auto and i need to put new pistons and cranke shaft and some other stuff to be able to run 10lbs of turbo right
Old 08-02-2010 | 02:25 PM
it has 207,000 im wanting to put a vtech in it then put the turbo
Old 08-04-2010 | 12:15 PM
g22cd5's Avatar
Supper Moderator
5speed auto?? it’s one or the other..if it’s a auto then it should only have 4 gears. If you are auto don’t even bother turbo your car. You tranny can’t handle it. What do you mean you are waiting for vtec?? Head swap? I donno much about the older accord but I’m sure they didn’t have DOHC engines in them. They were prob. SOHC engines..witch SOHC vtec is pointless!!! I donno why ppl think if it has vtec its fast cus SOHC vtec has nothing to do with performance its all about fuel economy. You might want to rethink your plan for your car. Cus if your gonna drop 3k for a turbo set up (yes that how much it cost to boost a car and that’s more or less on the LOW side of how much you SHOULD spend to boost a car) Then you need to swap your auto tranny out for a 5speed manual tranny. Also with that many miles I wouldn’t start adding anymore power over stock your just asking for failure. If you wanna boost I’d say do a full engine and tranny swap then start thinking about adding a turbo kit.
Old 08-05-2010 | 12:35 AM
clutch811's Avatar
^^^^^ cant agree more.
adding boost, especially on a budget is a big tricky game. you need to have lots of knowledge and skills under your belt if you want this. personally if the car itself is physically in really good shape and you really like it then go for an engine swap. the A series doesn't have much of an after market. Id say at least get yourself a low mileage engine from a 90-93 accord and swap it in. its a better engine and will make more power stock. also cheap and very easy to find.
Old 08-13-2010 | 09:17 PM
thank u guys good idvice im die en for a 5 speed trany thanks
99accordf23a5
05-06-2014 01:51 AM
brandyn
11-26-2013 06:31 PM
mamtsberg
03-17-2010 10:15 PM
ryan ortego
05-19-2005 07:06 PM
