nos system
RE: nos system
From what i have read NX is the best kit, b/c zex rates their hp to the crank and not the wheel. And everyone I have ever talked to says the next time they will buy NX, with the whole zex plugs most of the people that have themsay they are over rated.
RE: nos system
The difference between zex plugs and an ordinary plug is in the size of the ground strap. A regular plugs' ground strap has more surface area on them in comparison to a zex plug. The zexkit is a very easy install, on a 4 gen I would recommend placing the unit on the firewall behind the throttle body. I haven't used a nx kit before but have heard good things about them, I tend not to render an opinion on something if I haven't actually used the product before, never the less, nitrous is addicting... What are the rates/lb for nitrous where you guys are? Marbro you definitely want to have a strong spark to ensure that you are getting a complete burn.A basic ngk copper plug will turn into a glow plug in seconds running on the bottle and cause premature combustion or run the risk of the ground strap seperating from the plug all together.
RE: nos system
"I have a friend who was running a zex kit on his grand am, when he ran iridium plugs he blew multiple valves because of premature detination, he never had a problem running coppers"
???Blew multiple valves???Don't even know what that means! a "friend" w/ a Grand Am, let me guess I should just trust you too....And I'm assuming you wanted to say detonation.
RE: nos system
let me guess, youre attacking me on this one because i didnt spell check and you had english as a second language?
If you couldnt understand simple terminology to say that the n2o was a direct result of of multiple valves being destroyed and it only happened because of a high discharge spark plug, then i guess there are just some things that you choose to disbelieve because of a very limited perspective
I really dont care if you trust what I say, it doesnt change the fact that it happened. At the very least it gave him a good excuse to spend 6 grand and completely rebuild the engine.
And just so you dont question the engine rebuild, it only destroyed the valves, nothing else was damaged.
In the end.... it really does seem like youre just lashing out at people just cause you burned yourself by running with what someone said and didnt fully research it like you should have.
#17
RE: nos system
You are a moron! As far as ESL goes you wish I was an english as a second language student. Born and raised in NYC. I have BS & MS in computer Science from the Thomas J. Watson School of Engineering and Applied Sciences. My thesis for my masters was on integrating tcp/ip networks into aircraft. I write software under DO-178B, level B standard for flight critical software for more than 5 years. I have been doing research since the time you where in diapers. I can't believe that people are listening to the second hand information you been plagarising for 900+ posts, this board is filled with people like yourself, no offense to the people trying to reply with actual knowledge of a situation. You have danced around ever question I have asked of you. `n20 was the direct result of multiple valves being destroyed.' A more appropriate answer would have been something along lines of at least telling us in all your wisdom what kind of valve's were destroyed(ie. intake, exhaust), and an actual clarification of what `mutltiple valves destroyed` means(ie. burnt exhaust valves, swallowed a valve) something concrete. Your the type of person that puts a whole bunch of things that he's `heard about` on his resume and when asked about it in an interview doesn't have a clue that it was even on there, or if you do, you give some lame common knowledge answer to the question. But then again I most likely have a limited perspective un like you write. Let me venture a guess your still in high school and don't know what a resume is, here's your time to show off your superior research skills. You are a poster boy for what is wrong with youth in this country.
#18
RE: nos system
I say you have a limited perspective because of your inability to accept that what someone is typing might be true. On top of that someone who develops an ego just cause they havea masters degree then only reads between the lines enough to assume that a person is a stupid kid just starting highschool only proves that you dont have any intelligence beyond the happy limited book intelligence.Saying youre from NYC doesnt mean crap,basic english is a second language in that city. I dothink it is cute that the best you could come up with is how to integrate TCP/IP in aircraft as a thesis, after all, someone who claims to be so great should have come up with something better then that. As for plagiarism look up the meaning of the word mr. MS I havent taken any words from someone without giving proper credit.
And to think, this moronic arguement wouldnt have started if you didnt feel the need to make your snide comments of "oh and im suppose to just believe you" give me a break, people can verify 80% of whats said on this forum and on top of that you outwardly attack because you dont get the answer you want.
#19
RE: nos system
80% correct guess if that's the type of confidence your looking for, it's ok. So what did you your thesis on? Bye the way Boeing's next generation 787 Dreamliner aircraft is using integrated tcp/ip networking for sensors with a Partitioned RTOS. You are so ignorant. I never claim to be smarter than anybody else for having a masters, I just state facts about things that I have done in my life. Where you my friend seem to project fact from other peoples expierences. You are a moron, don't have kids!
And what you write could be considered a form of plagiarism.
http://www.reference.com/browse/wiki/Plagiarism
