old but old.
old but old.
how much pounds of boost will take to run 500hp
what needs to be replace besides all the internals
resleeve and wat kind of turbo gt-35 or will the garrett t3 t4 will
be able to push that much..no h22 fully f22...
rather go with the f20b then h22 thanks guys
just want info and any help so i can learn and b prepare in the
next couple of yeaars...thanks
RE: old but old.
wow............alot of parts,alot of research and ALOT OF MONEY my friend...i know people that have boosted their V6 on the 6th generation around 300's but i've never seen anyone hit 500 yet...but hey anything is possible....just make sure you have a never ending fountain of money because i'll tell you now...you're looking at around 10,000's right now..
RE: old but old.
A 10 lb can of nitrous, assuming constant and full pressure (aka a ton of heat) will give you 500HP for 12 seconds. You will also need a full secondary fuel line and high pressure, high volume fuel pump and a new engine. Chances are that your engine will withstand about 3 of the 12 seconds before the head gasket blows out, the rods shatter and the nitrous burns holes through all ofthe pistons. Then, the oil ignights, burns back through the intake, lights up the filter ..... and you better pray that the fuel pressure regulator(s) keep the flame from your fuel lines.
Other than that, why not?
RE: old but old.
Shadow1992 has not been on here since November of last year, but he used to be a great help with turbos and other stuff. I'll copy and paste what his signature says he has:
1992 Accord EX
massively modifed H22A
2.5L stroker kit
GT35R turbo @ 24psi
459 whp
404 ft-lbs torque
As you can see ^, he has an H22 that has been stroked and probably doesn't much resemble an H22 anymore. He'spushing 24psi and isn't getting 500hp.
I doubt you're gonna get 500 out of an f22 without spending at least $50k on it.Total waste of $ IMO.
1992 Accord EX
2.5L stroker kit
GT35R turbo @ 24psi
459 whp
404 ft-lbs torque
RE: old but old.
thanks guys
im not going with nitrous im skared...lol
money yea its an issue but dats what i want the f22...
yea i seen shadows signiture dats why i put this post...
i dont really care if its front wheel its just for my pleasing u know..
if that i rather get an old datsun and puta skyline engine....lol
but can it been done to a long long long long point can it be done....lol
