Turbo Setup
Turbo Setup
Ive got a 98 F23A1 Accord and ive slowly been looking around, piecing together my turbo kit. I wanna run 6-8psi of boost and i was wondering if there is anything else i need in order to do so. So far ive sought out...
-Cast Turbo Manifold
-Turbonetics T3-T4 turbocharger
-Tial 38mm wastegate
-2.5in Intercooler Piping Kit
-Yonaka 18x6x2.5 intercooler
-225lp fuel pump
-Apexi Neo
-Map bypass vaulve
-440 DSM injectors
-Complete turbo Oil Kit
-still looking for downpipe, let me know if u have any suggestions
ive been looking at other peoples setups and ive seen many with more and many with less items then i have. I am wondering if this will be adequete to run 6-8 psi.
Thanks a Bunch!
-225lp fuel pump
-Apexi Neo
-Map bypass vaulve
-440 DSM injectors
Thanks a Bunch!
RE: Turbo Setup
I never found the downpipe for mine so I just bought 3" piping and made my own (needed to weld). Ur gonna want a better spark, so u may want to consider a MSD 6AL and new MSD wire plugs and NKG iridium plugs...
That's all I can remember @ 8.28am @ workand w/out any sleep...
RE: Turbo Setup
remember that 6psi is safe and 8psi is a max for stock internals... mine is at 7.21psi...
if you're running an AT u may wanna consider a tranny cooler... actually... is a must... (shame on me, i don't have one...)
RE: Turbo Setup
change timing belt as a caution and remember those are the big things... ur gonna find out all u need when u start puting it all together... good luck and i think im missing something...
I'll get back at u if i remember
jgryz450
05-27-2012 02:53 PM
