burnout
Old 06-06-2006 | 02:32 AM
2002haccord's Avatar
Default burnout
how do you make a 2002 honda accord burnout. ive seen it done on a video clip. and the car was stock
Old 06-06-2006 | 09:25 AM
YeuEmMaiMai's Avatar
Default RE: burnout
V6? I4?
The easiest way is to smear some petrolium jelly on your tires and stomp on the gas (really works).
On a more serious note abusing the car like that will result in some expensive repairs as Honda parts are NOT cheap and while they will hold up really well, repeated abuse will take their toll on them.
Old 06-06-2006 | 10:29 AM
mbo1985's Avatar
Default RE: burnout
if you have a stick shift, dump the clutch at 2000k or so.
I snapped a driveshaft once from doing something like this, so be careful...
Old 06-06-2006 | 12:44 PM
Default RE: burnout
I dont know if the car was a 6cyl or 4cyl but i was just wondering i tried it by holding the e-brake and it does only if the pavement is little wet but only smokes out on the passenger tire.
Old 06-07-2006 | 10:16 PM
jesse6's Avatar
Default RE: burnout
ORIGINAL: 2002haccord
thats because you have an open differential(power goes to the tire with the least resistance.)
Old 06-08-2006 | 02:44 AM
Chiovnidca's Avatar
Default RE: burnout
You can try moveing the steering wheel side to side a little to get the left one going too. It works at the dragstrip with slicks anyway.
woody31
01-09-2015 05:52 PM
kylemiller123
02-09-2009 08:45 AM
Briggz
03-28-2007 05:44 PM
Quick Reply: burnout
