CRAZY PROJECT
CRAZY PROJECT
So my goal is 210hp all-motor while staying with the SOHC set up while using mostly stock honda parts and remaining at a $1700 budget including car, I bought a 93' 4 door Accord LX automatic with blown head gasket for $400.00 bucks. The motor was so bad that all the plastics including wires melted to the head and block. Well after a day of shop'n around i found a 2.3 SOHC VTEC outta of an 02 accord $350, I bought it and stripped it down, pulled the head off and noticed that the ports on the 93 head were HUGE compare to the tiny ones on the 02, so I scrapped the Vtec head, in favor of the 93 head, ( more air more power right?) on top of that i took the head and shaved it40 thousandths of an inch,($60 bucks)which should sky rocket my compression up from 8.8 up to like 10.5.1( might be off by a little, but very close) the motor runs strong with a hell of a pull once it passes 3800 rpm, and burn outs never felt so easy.125hp stock the newpower is around 155-165hp not official but compared to the cars i've been beating it's a good guestamation, and I'm pretty good when it comes to guestamaions-my next plan is a cam gear($65 bucks),so i can adjust the cam since I shaved the head (good for about 3-8 hp), next would be an Intake Manifold from a 92-93 ex/se accord($50 bucks)which has 8 runners on it (good for about 8-15hp) , 92-93 ex/se cam, and ecu($100) good for about (4-9hp)- and a Prelude throttle body($75) (good for about 2-5hp at high rpm)-I should expext at least a good 17- 28hp increase in stock parts alone
Now after all that is done, I plan to do the simple bolt ons like- cold air intake($50) (good for5-10hp) - header plus full cat-back and free flow cat($325) ( good for around 12-20hp)
Then a good set of ground wires($25), 8.5mm spark plug wires, platinum 4 spark plugs,optima batery ($220)(good for around 3-10hp)
With a little tweek'n i'm sure I could hit the 200hp
It would be nice to hear some feed back or any usefull information, let me kno what you guys think
RE: CRAZY PROJECT
Thanks, I appreciate it- and yes I did all the work myself (minus the machine work) I'll have pictures soon, but as for now I'm going for complete sleeper, I even have the stock 14's that the car came with, I'll take it to the track in about 2 weeks just to see what it runs, Also I have a question- Would you know what the weight of my car is ?? its a 93 lx 4-door
RE: CRAZY PROJECT
RE: CRAZY PROJECT
ORIGINAL: jaeal
check this out.... you cant really expect that you will get 200whp for what you are wanting to do
http://www.honda-tech.com/zerothread?id=1495684
RE: CRAZY PROJECT
a 2.2l engine having larger cylinders then a 2.3l engine that has a 1 mm larger bore and 3 mm longer stroke....... unless that engine you had was previously modified i dont have any idea how you could say it was a better block... your losing a little hp and torque based on the fact that the f22 engine is a slightly smaller engine.... sorry, that kinda goes against the basic engine design
RE: CRAZY PROJECT
hehe, sorry, looked back at your post/fully read what i quoted and yeah, i blocked out the head part sorry / but i dont think youre going to gain 15/20hp just from larger ports on the head maybe after you have the intake/tb/intake manifold but just off the head im kinda iffy. find someone to dyno the car for free from that ^_^ prove me wrong so i have an excuse to take off my f23 head and port it lol
but honestly look at that one post i linked..... you may find some interesting and helpful information
once again, sorry about my confusion
and when you talk about the intake manifold youre putting on is it a prelude one with IB's?
RE: CRAZY PROJECT
well the intake runners's on the intake manifold are a lot bigger than the F23-- You should go to a parts store and look at the intake and exhuast gaskets and comepare them to yours and see the diffrence, plus I shaved the head 40 thousandths of an inch-- compression around 10.5.1 and larger intake and exhaust should be good for at least 15-20-- I'll get it dynoed when I get the ex cam and intake manifold, so I could see what those stock parts would do.
RE: CRAZY PROJECT
I'm always amazed at how cheap engine machine work is.... I recall reading an article a year or two back about them port/polish/sleeve and a few other misc. little tasks and it was only like $1100.00 for all the work/parts and made one nice little n/a engine...
