Crazy Sleeper Idea
Crazy Sleeper Idea
So I've been thinking about this for a few days. How to make the "ultimate sleeper" and here's what I've come up with so far. Tell me what you guys think. I think it would look sick if done right.
The car looks stock, it can't appear to be to extreme at first, but there will be one switch under the dash that simply says "wake up" You flip the switch and it lifts up the exhaust silencer out of the way, then the turbo blow off lines will be run down behind the wheel in the front and have a small cover over it so it doesn't look like anything is there, this cover will also slide back when the switch is thrown, then the airbags lower the car to optimal stance, the dash and rear bumper will be re-done in fiberglass, each one of these pieces will have one area of it that's thin but will look normal at first, once that switch is thrown a light comes on that has a stencil in front of it that says "sleeper" so that word now shines through with illumination, the underside of the car will also be illuminated. There should also be a little sprayer that will put fluid on your tires that makes them grab traction better (I think bleach will do that but I'm not certain).
So this seeminly stock vehicle will all of the sudden become one mean modified, loud machine... Can you imagine sitting at a light with some jerk off revving his engine then you flip a switch and the car just lowers, exhaust gets louder, the blow off valve sounds and illumination comes on? It makes me smile just thinking about it. And of course the motor will put out at least 400HP
RE: Crazy Sleeper Idea
ROFL. That link isgreat!
Hey nasty. I would like a sleeper that always looked stock but had a ridiculous amount of power. I mean even stock ugly wheel covers like my 2000 LX has. No switches or extra weight, just raw power on the inside, and Grandma'sgrocerygetteron the outside.
Since I am at work I got to put some thinking into it as well. Two ways to do it:
1) Spend a lot of money on a nice hydraulic suspension and custom piping/wiring to hide everything. Weight gain isnt an issue if you use ceramic/kevlar/aluminium parts.
2) Hide a nitrous bottle somewhere, get the fake turbo sound kit, activate fake turbo kit, double shot the nitrous and hope the engine holds together.
If they can make hard top convertables, I am sure we can make a weld on a piece of metal to a couple of power window motors. I think we might need more then 2 if you want the wing all the way out before the light turns green though.
