A Poll... What tool do U use Most ???
Old 01-31-2011 | 11:57 AM
I have both types of torque wrenches, and find that both are useful at times. The beam torque wrench is accurate for small diameter bolts, but a bit awkward. The click/release ratchet torque wrench is good up to 150 ft-lbs which covers most larger bolts.
Regarding tools, I have several that yield pleasure when they solve a problem.
1) wobbly sockets - When you need a bit of flexibility and misalignment w/ power to break a bolt or nut, these work wonders. I couldn't live w/o them.
2) Magnetic screwdriver w/ interchangeable screwdriver inserts. Holding the screw w/ magnetism provides a valuable third hand at times.
3) Ratchet driver w/ flexible extension. This allows access to screws and bolts that are impossible otherwise. Another tool I couldn't live w/o.
4) OBD2 scanner - Impossible to properly diagnose any modern car w/o them. The added features of scanning and graphing can be very useful.
regards
Instead of wobbly sockets (which are available also), I actually meant wobbly extensions. W/ these you get a misalginment at each extension joint and where extension meets socket. However not where extension meets ratchet.
regards
  #22
Old 01-31-2011 | 01:57 PM
07_Accord_SE's Avatar
Craftsman open and boxed wrenches.
Buktheng
01-27-2008 06:20 PM
nafango2
12-14-2007 11:52 PM
trihonda
01-15-2007 09:10 AM
12-04-2006 03:53 AM
thunder_x
05-05-2006 10:11 PM
Quick Reply: A Poll... What tool do U use Most ???
