Sea Foam!??
RE: Sea Foam!??
Easy there killer. Check out or DIY section on how to use it.
As for what it is. Basically it's a detergent for cleaning your car. It does for your cars oil, engine and gas what dawn does for dishes.
1/2 Can in the Brake booster line
1/2 can in the oil (in place of some oil)
and a seperate can to put 1/3-1/2 into the gas tank over 2-3 fillups
There you go, how to clean your motor without taking it apart.
RE: Sea Foam!??
usually its about $6 a can.
bear in mind after you put it in your oil, drive around at high rpms for awile, then CHANGE YOUR OIL!
seafoam isnt an oil additive... its not meant to stay in your oil.
RE: Sea Foam!??
ORIGINAL: smaglik
search on this one buddy.
i've used it. it was useless.
