2014 Clunk/pop noise... PLEASE HELP!!!
I have 2014 accord sport with 10,000 miles. Recently it started making a popping noise like a metal slipped and shifted to the other side when i turn the wheel. The noise only happens when I try to pull out of a parking spot by going forward turning the wheel to left then reversing turning the wheel right and moving fwd again. The pop happens when I turn the wheel to change direction to left or reversing and the wheel is turning right. It only pops once. I took it to the dealer and the technician said its the break pads resetting itself. Its very annoying for a new car and I doubt its the breaks because its coming from the driver side only. The popping is very loud and rough on the hill compare to flat surface. PLEASE HELP!!!
sounds like a tin can?? go back to the dealer and demand a further inspection, they blew you off the first time and for the amount of money you spent you deserve a more reasonable explanation. And if they tell you the same crap again tell them to spend 25/30k on a car and see if they would put up with it, i dont think so,
Hello Member
