Which Acura anti-sway bar for 4cyl 2dr 01?
Which Acura anti-sway bar for 4cyl 2dr 01? I was thinking I would need one from the Acura CL because its a 2 door but I'm not sure, so I was wondering if anyone can verify that it fits for sure. I only plan to get the rear anti-sway bar based on what I read in some other posts (but they were referring to 03 7th gen not my 6th gen). Will I need a front anti-sway bar too? This is the page I am planning to order from.
http://www.acuraautomotiveparts.org/...&catcgry4=
can anyone tell me which specific parts I will need and from what year and trim Acura CL?
RE: Which Acura anti-sway bar for 4cyl 2dr 01?
I ordered an '04 TLrear sway bar from an online Acura dealer. Fits perfect. Make sure you get the bushings and brackets too. Your old ones won't work. While you're at it, you may as well order new sway bar links. Unless you know for sure the threads on your old ones are like new. The allen wrench threads on the links strip real easy. I can't remember which website mine came from, but it'll be easy to find.
And, not to sound like a jack, but there's a ton of stuff on sway bars if you search for 'sway bars' in the Suspension forum.
thanks for you help peter. i did searches and couldnt find anyone who was doing this to a 6th gen 2 door (i found 6th gen 4 door and 7th gen 2 door). is there a difference between the rear sway bar i need depending on if its 2 door or 4 door? do you have a coupe or a sedan peter?
Mine's a coupe, but I believe they're the same as the sedans. And the TL is the same too, 4 or 2dr.
It's not a bad job, and one of those mods that has great results for minimal bucks. The icing on the cake is that the improved handling doesn't come at the expense of harsher ride.
p.s. don't feel dumb; I changed my sig after you asked what model I drive.
