DIY rear and front upper strut bars
Old 08-02-2007 | 12:39 PM
ohsmustangs09's Avatar
Default DIY rear and front upper strut bars
i have a 95 accord coupe ex and i need help with installing mainly the rear upper strut bar....any info greatly appreciated, thanks!
Old 08-02-2007 | 03:41 PM
sir_nasty's Avatar
Default RE: DIY rear and front upper strut bars
Peel down/back the carpet, get a lineup on where the bar will go through the carpet to attach to the upper part of the strut tower. Then remove the ends off the strut bar that bolt to the top of the strut tower. Now you just have a bar, cut an X or + into the carpet at the point that the bar is going to pass through it, slide the bar in, re-install the ends that bolt on, remove the 3 upper strut tower bolts, slide the end of the bar over the bolts, re-install the bolts and torque to specifications.
Old 08-02-2007 | 05:09 PM
Seems easy enough, thanks!!
Old 08-02-2007 | 06:25 PM
sir_nasty's Avatar
It should be fairly straight forward, I've put them on a few civic's without issue.
Brent Paul
06-13-2014 07:23 AM
big_pd
03-25-2011 11:16 AM
AWeb80
05-02-2008 02:30 PM
trukid21
03-28-2007 02:22 AM
aka1109
01-10-2005 03:19 PM
