Dose this look like a decent coil over kit
Old 08-08-2007 | 12:28 PM
87hatchback's Avatar
Default Dose this look like a decent coil over kit
I found these, http://www.slickcar.com/productdetai...ProductID=1680, they look good to me, but I have know idea what good looks like lol What do you think.
Thanks
Marshall
Old 08-08-2007 | 01:02 PM
finch13's Avatar
Default RE: Dose this look like a decent coil over kit
Those don't looke like a true coilover kit. It appears that you would have to buy a threaded shock or they sit in the sprint seat and you can tighten/loosen the spring. Don't look very reliable and I wouldn't trust new springs that cheap and especially not a "coilover" set as they describe it. If you want real coilovers you should be looking in the $600 to well over $1k range for a new set.
Old 08-08-2007 | 02:10 PM
thanks
Old 08-09-2007 | 11:46 AM
finch13's Avatar
If you're looking for a cheap drop I always recommend the Eibach Pro-Kit. 1.2 inches fornt and rear and use the stock shocks. No camber kit needed, just an alignment. $190 from tirerack.com
Old 08-09-2007 | 01:37 PM
sir_nasty's Avatar
Dropzone's aren't horrible.... they're not the best either, if you used them you can expect a fairly bouncy ride, a better look and average handling, those threaded sleves simply slide over your existing shock and provide adjustability. If you want inexpensive about the best/cheapest way for a decent setup is KYB Shocks with Neuspeed coilovers. That'll get you started but it's not going to be a real race setup but it will look nice and handle better than stock. Don't forget, anything over 1" drop will require a camber kit!
Old 08-09-2007 | 11:46 PM
finch13's Avatar
The $107 price tag for coilovers threw up a huge red flag for me
Old 08-18-2007 | 05:43 PM
thanks guys
Old 08-19-2007 | 01:35 PM
03Sleeper's Avatar
finch, eventually you're gonna have to replace your stock shocks/struts...OEM can handle only so much pressure for so long.
Old 08-19-2007 | 03:23 PM
finch13's Avatar
Yeah I know, I'm not looking forward to that day. I only recommended a cheap drop, not a long-life performance suspension.
phantomgrey92
10-09-2013 05:45 PM
rico1980
08-07-2010 09:21 AM
Jasper44
03-17-2009 02:13 AM
jmcmichael08
10-14-2006 07:15 AM
Quick Reply: Dose this look like a decent coil over kit
