Good replacement stock struts for a 98 accord?
I am looking for good stock replacement struts for a 98 accord. I don't need anything for better handling I just want struts equal to what the car came with in terms of quality and ride comfort. Are KYB GR-2 struts a good choice? Also the vehicle has 140k miles, how long do the factory strut mounts last? When should I replace them? The vehicle has never seen road salt.
KYB GR-2 and Koni STR.T are good replacement struts, I'd probably go with Koni's over the KYB though. Tokico also makes a good replacement shock too.
Strut mounts? The front spring and strut sit in a perch that bolts to the engine bay, as well as the rear. The lower portion of the struts front sits in a fork and the rear has a bushing that gets bolted to the rear hub. The parchs and forks should be fine, the only thing I'd replace are the fork and hub bolts, which are about $5-8/ea and you need 4.
isenegger
02-11-2008 06:29 AM
markg360
12-29-2006 04:16 AM
