Help needed purchasing Struts
Old 10-05-2008 | 02:36 PM
junker
Default Help needed purchasing Struts
I am thinking about replacing my 2000 accord LX V4 rear struts (or shock absorber?). I am considering Monroe Sensa-Trac struts (part no. 71299) for replacement along with the mount kit.
Is that a good brand? and the correct part? I went on honda's website and it says I have shock absorber not strut. The mechanic said its a strut. I will appreciate it some one can help me understand.
Also, I am considering getting my timing belt replaced. can anyone suggest a good timing belt kit and water pump?
I will really appreciate it.
Thank you
Old 10-06-2008 | 01:49 AM
xpieceofcralpx's Avatar
Almost A Senior Member
Default RE: Help needed purchasing Struts
struts and shocks are the same thing..diffrent name for the same part.
uhm, are you looking for performance? or just a simple oem replacement setup?
Old 10-06-2008 | 10:05 AM
falkore24's Avatar
Struts are only in front. For OEM replacement, Monroe's are pretty good.
Old 10-06-2008 | 11:22 AM
finch13's Avatar
I personally would never get Monroe, there are so many better manufacturers for a few extra dollars.
Falkore is correct, struts are only in front, but struts and shocks are pretty much interchangeable, I just call them dampers so I don't confuse people.
For the timing belt - Honda OEM is always the best bet there, as the timing belt is a crucial part of the engine. But, if you can't afford the OEM kit, Gates makes very good and reliable belts.
Old 10-06-2008 | 05:31 PM
falkore24's Avatar
Also budget for an oil pump .... while doing a timing belt, it only makes sense. Also, Honda only for the timing belt. Gates are good as noted, but I'd only use OEM for a belt that goes for 100k miles.
tyme
10-25-2009 01:49 PM
bottlerocket
03-02-2008 06:50 PM
BostonPuppyDawg
10-03-2006 02:24 AM
OkieDoke
07-12-2006 12:29 AM
96accord
05-28-2006 11:42 PM
