high speed vibration ?
I've got an '03 Accord with Brigestone Potenza tires, 75,000 miles. After many re-balances and an alignment check, I still have a small vibration at 80 mph. Could this be a wheel bearing going or someother mystery issue like a sway bar link bushing going bad.
RE: high speed vibration ?
go and get your wheels balanced again they didn't balance them correctly they most likely used the wrong weights and or possibly a loose wheel. Have them show you the alignment also i would just take it back there and have them show you each wheel weighs out to 0 after balance
ORIGINAL: david369601
second reason: I had a tire that got a bunch of mud and crap in it somehow, didn't vibrate until 75. The shop took the tire off cleaned it out and everything was fine
ORIGINAL: smaglik
bent rim?
bent rim?
ORIGINAL: sir_nasty
I've had this happen for two different reasons on two different cars. One car they used rather large wheel weight which made them balance out but it needed to be distributed differently to prevent the vibration. so instead of one 5kg weight you use 5 1kg weights next to each other.
ORIGINAL: falkore24
LOL ... nice catch!!! Nate??? Did you mean grams?
iluvsnapple
08-19-2011 07:51 AM
Steviinicks
01-04-2011 04:40 PM
bikener
06-06-2008 04:06 PM
