Jacking up my 2006 Accord Problems...
Old 06-06-2009 | 06:12 PM
CYANiDE's Avatar
Default Jacking up my 2006 Accord Problems...
This may sound really noob, but I just can't find the right spot to place my jack to change my left rear tire. I found 2 points, which don't even raise the car even if the car jack is at it's max. I only see a few other places, but I fear that something will bend inward if I place my jack on them...
Any pics or good descriptions about where they should go?
Old 06-09-2009 | 08:16 AM
thebigone
Center front (cross member) or center rear of the car ( where the tow bar is) otherwise the lifting point for the front side will be just below the front fenders where the bottom of the door meets the bottom of the fender. On each you should see an indentation, between these indentations are the lifting points. For the rear sides it will be just below the rear door corner closer to the rear tire area. You should see these indentaion as well. Likns to some pics. Hope this helps.
http://i89.photobucket.com/albums/k2...u/DSC06905.jpg
http://i78.photobucket.com/albums/j8...JackPoints.jpg
Tony1M
05-08-2011 03:23 AM
thunder_x
05-21-2007 09:21 PM
j_man_honda
01-11-2007 08:29 PM
wayneboard2
12-19-2006 02:59 PM
mckeand13
11-21-2006 02:33 AM
