Lowering the accord finally
Old 04-29-2008 | 11:09 PM
BuntinBoy9's Avatar
Default Lowering the accord finally
hey i plan i getting tein basic coilovers for my accord this summer currently the suspension is all stock but im rolling on 18" enkei or52's so here is my ? i wanna lower my car like 2" maybe more if i can so what should i put the ride hright as and what type of camber kit do i need to get and from where for how much .... preciate it
Old 04-29-2008 | 11:46 PM
finch13's Avatar
Default RE: Lowering the accord finally
Measure the height your car is from the fender to the ground before you install. Install the coilovers and lower them until the car is a low as you want it. Camber kits are pretty spendy, I know there are a few around.
Old 05-01-2008 | 07:54 PM
BuntinBoy9's Avatar
ok cool i have measure it now and from bout the lowest point i have 6 1/2 inch clearance soooo
Old 05-01-2008 | 09:06 PM
j_man_honda's Avatar
Easiest thing to do is just take off you stock struts/shocks/springs, measure them from top to bottom, then set your coilovers overall height 2" shorter than the factory ones. Just remember, the springs on the coilovers will settle a 1/4"-1/2" over the first 4 weeks of riding on them. Are you doing the install or what? If you have zero experience with suspension id recommend a mechanic do the job. And camber kits can be found on ebay reasonable. I got mine off there, i think the brand was springtech or something like that.
Old 05-01-2008 | 10:20 PM
BuntinBoy9's Avatar
ok ya it would be my first time doin it but i have the research done and a guy who put springs on a 91 integra to help me also sooo... is that good enough???? my dad would be halpin also and he is almost done building an airplane... handy person he is
Old 05-01-2008 | 11:22 PM
ORIGINAL: BuntinBoy9
Yeh you should be god then. I mean its pretty straightforward. Its just getting them set to the right height that is time consuming and aggravating
Old 05-01-2008 | 11:48 PM
peter4jc's Avatar
That's true. Man, I was happy when I put the car back on the ground and the height was where I wanted it. After all that, the last thing I wanted to was put it back on jack stands, take off the wheels, and adjust the coilovers again.
Like j_man said, measure the stock units, and then adjust coilovers. I like to measure the car's height at the top of the wheel arches on the fenders, just for reference.
Old 05-03-2008 | 03:52 PM
BuntinBoy9's Avatar
ok kool but should i air on the caustion side and put like 3/8 of an inch (in between the 1/4 and 1/2 inch expectance of the car settleing) so that i could guesstimate it and try to get it close to the ride hieght that i want???
Old 05-03-2008 | 09:04 PM
If you want too, why not... Im not sure of the exact amount but the springs will settle some, not much but some
Old 05-03-2008 | 11:11 PM
BuntinBoy9's Avatar
ok kool well i will air on the side of caution a little bit then how much did urs settle and what brand do u have?????
Tomtn2008
02-21-2008 12:38 PM
02Hawkord
02-21-2008 11:57 AM
GirlyAccord
02-19-2008 11:22 AM
tunedis95
04-22-2006 09:43 PM
gookie monster
02-22-2006 11:59 PM
