lowering my car
lowering my car
I bought my 1995 accord from a friend of mine a few months ago and he had lowered the car before hand. when i got it he put brand new tires on it and now, 4000 miles later, the right front tire is really bald on the inside, theres steel showing and he said its doing that because the is lowered..is this true? and if it is or isnt, how could i fix that?...I dont know much about cars but i would really like to "be my own mechanic" soon
When it's lowered, the suspension needs to be re-aligned. Severe tire wear can be from lowering & then NOT aligning the car. Camber & toe are usually to blame.
Alignment is one of the few things that don't really lend themselves to DIY mechanics.
yes there is definitely an alignment issue however bald after 4000 miles is very bad. that sounds like your toe is way off than anything. camber causes wear but not that bad. even at like -3 camber. the killer is a combination of camber and toe. the toe will wear out the surface contacting the road very quickly. my back left has the same issue.
how much is this car lowered? id say dont just jump on a camber kit. take it to a shop and see if you can work a deal. get them to align it and then see what camber is off. (they can fix toe without any kits on our cars). they will even let you know if there is a problem is other components. then see if they will let you install a camber kit and come back for another quick alignment no charge. worth a try.
You need a camber kit. Simple.
People always say toe is more important. Well, when you have any camber that is more or less than +/-1 degree, you need a kit. When your tire is / or \ you WILL have camber wear. It is stupid to not get a kit, then realize that after you pay for an alignment and go through another set of tires you need camber kits, new tires, and another alignment.
I would recommend SPC or Ingalls balljoint kit for the front. (I have Ingalls)
And Wicked Tuning for the rear.
Good luck and get the kits asap.
thunder_x
04-21-2007 06:28 PM
