Mixing shocks..?
RE: Mixing shocks..?
Hi Member:
Shocks and struts are engineered to work best with there own make and model, there fore I will have to say no!
ClickPic!
[IMG] local://upfiles/22/37B74CBC9FE945FE9E698140E83B1B4C.gif[/IMG]
[IMG]local://upfiles/22/37B74CBC9FE945FE9E698140E83B1B4C.gif[/IMG]
ClickPic!
ORIGINAL: ohsmustangs09
Say, for instance, I put two shocks of (a) kind in the front, and two shocks of (b) kind in the rear...Would this work?
just curious..
just curious..
If you're doing it as a cost spreading stepping stone to upgrading all the dampers in time then personally I'd do it. If you were intending to upgrade to something a bit special like Koni Sports ('yellow') then you could initiallyfit the Konis at a soft setting (to more or less match the existing other dampers) until you get around to fitting new dampers at the other end, after which you might want to stiffen up all round(?).
That makes since...I didnt think about how that would effect the handling...but i was just curious...
What are your opinoins on KYB GR-2 shocks? and, for instance, Eibach Pro-Kit springs??
I got those springs but no shocks yet! cant decide....
95F22B2
09-27-2011 03:56 PM
