Stock front dual piston caliper upgrade
Old 10-18-2010 | 10:34 PM
ohfindlay's Avatar
Default Stock front dual piston caliper upgrade
Not sure if anyone else has ever done this as of yet, but I just had dual piston calipers installed on my '03 Accord 6cyl 6spd Coupe, from a '95 Acura CL 4dr legend. Along with the other upgraded brake components, this car can really come to a stop, like right now. I'm extremely happy with the suspension and brake components as a whole! Anybody ever heard of this swap before. I guess I do things backwards, I've upgraded the handling and stopping capabilities of this car before going for the torque and power.
Old 10-18-2010 | 10:58 PM
Hi New Member..The brake up grade has been done many times.
Thank You for joining the forum and By the way! Are You from Findley, Ohio?
Old 02-09-2012 | 01:26 PM
rgr 96 monstro's Avatar
Default caliper upgrade for accord
New to this forum, and been looking to do a brake upgrade to my 96 sedan interested in the legend caliper(fo front)r what exactly do I need for the front swap and for the back I have drums can I use also the legends rear set up or should I stick to an accords ex.???
Old 02-12-2012 | 05:54 PM
g22cd5's Avatar
Supper Moderator
for the rear brakes you will need to swap the WHOLE rear set up from a 5th gen accord that has rear disc set up. You will also need to swap the rear cross member to attach to rear swap bar.
As for the front upgrade you will need to do some research but from what I remember reading when I was looking to do the same swap. You need the WHOLE knuckle set up for your front...I would suggest searching on this one. I don't recall anyone on this forum who has done the swap your looking for answers in.
Old 02-12-2012 | 07:55 PM
Is it a must for me to replace the cross member can I avoid the(stock) rear sway bar and as for the front swap I haven't found much info....ppl say they have done it but no info on how to do it
cukaracha
11-25-2014 10:10 AM
kaotiklivin4eva
03-31-2013 04:31 PM
gdoyler
08-13-2012 11:57 AM
caligirl
08-24-2008 12:45 AM
rodmathews
08-05-2007 10:49 PM
Quick Reply: Stock front dual piston caliper upgrade
