Strut and Sway Bars
#22
RE: Strut and Sway Bars
ORIGINAL: sir_nasty Sway bar (aka anti-sway bar): In the simplest of explinations when you corner the body rolls to the outside because of centrifical force. When it does this the natural order of things is to start lifting the inside tire up so it has less contact with the road. A sway bar tries to push that inside tire back down when the outside tire goes down.
Assuminglateral acceleration, and thus total lateral weight transfer remains the same (i.e. the sum of front + rearweight transfer remains constant), if the stiffness of a singleARB is increased then the amount of lateral weight transfer will be increased at the end of the car at which ARB stiffness has been increased, and weight transfer at the other end will beequally reduced.
Assuming no change in lateral'G' force, the sum total of lateral weight transfer (front + rear) will remain the same, but the distribution of that transfer (front vs rear) will change. This is why (e.g.) increasing the front ARB stiffness tends to increase understeer, i.e. more weight transfers from the IF to the OF, but also equally less weight transfers from the IR to the OR.
This moves the grip balance toward the rear, i.e. more equally distributed rear weight, and less equally distibuted front weight, which in effect equates to more 'rubber on the road' at the rear than the front, thus more understeer / less oversteer (with an increase in front roll stiffness).Of course the opposite affect will occur with a rear ARB stiffness increase (or reduction in front ARB stiffness)
If front and rear ARB stiffnesswere increased equally then the grip balance would remain the same and theundersteer / oversteer balance would be unchanged. What would change is the degree of roll (lessened) and the the general steering and handling responsiveness (increased). In this case there would be no change in the 'lifting' affect at either of the inside wheels, the degree of weight transfer would remain the same (assuming no increase in 'G' force, which will probably change), though the speed at which the weight transfer occurred would be faster (hence more responsive handling characteristics).
#23
ORIGINAL: sir_nasty
the biggest thing you need/want is Solid core (no hollow crap)
For tower braces where the bar is not bent in any way a tubular bar is usually adequate, but as soon as a bend is placed in the bar it becomes much weakened in both compression and tension, so solid would be better as would much larger external dimensions. Note also that bars that have a flattened bar section / shape tend to beweaker in compression (and tension if a bent bar).
and good contstruction/welds on the pieces that mount to the towers, if you find those things then names make no difference.
#25
I loved my Comptechs. Progress also makes an excellent product. I think that Tanabe and ST are the same company, but I might be wrong. I know that they make good strut bars, but I don't have any experiance with their sways.
#27
http://progressauto.com/store/produc...roducts_id=407
Spoonfeeding at it's best! Next time look it up.
#28
kool! thanks! I'll try to find pics for that and see how it performs! I saw the ST installed on a 97 accord in the project car mag and since my cars green it would look nice! But then again i saw the tanabe's install on a 94 accord on project low key in modified mag and that looked kool as well! So i'm just debating on what is better!
#30
I bought front and rear strut bars, so far Ive installed the front and am working on the back, which are a bit tricky to get to. Got em from ebay, but I was very selective about them. The bars are made out of aluminum, the mounting pieces are made out of steel, the bar is thick, and I did notice a difference while driving, steering has become more responsive. Cost 45 bucks (shipping included) for both the front and rear, so yea Id say go for the ebay ones, just be on the lookout for ones that are thin because they will likely bow under high stress.
