suspension overhaul
Old 05-13-2008 | 06:40 PM
hotnics82
Default suspension overhaul
I'm doing my stuts and springs on my 97 4 door. What struts would be the best to pair with h&r oe sport springs (lowers .75")without sacrificing ride quality. what other bushings and bolts will i need to purchase?
Old 05-13-2008 | 06:53 PM
finch13's Avatar
Default RE: suspension overhaul
Adjustable: Koni Yellows/KYB AGX
Non-Adjustable: KYB GR-2/Tokico Blues
That spring isn't going to be much stiffer than the OEM ones, so you would be fine with any of them.
If any bushing are worn out, you'll want to get new ones pressed in. Everything else should be reusable.
Old 05-13-2008 | 07:00 PM
hotnics82
what bushings are we talking about? Can someone tell me or send me a link to replacing the struts and springs.
Old 05-13-2008 | 07:03 PM
finch13's Avatar
It's pretty straight forward. There are 14 nuts and 4 bolts you have to remove just to take the struts off of the car. Then remove the nut on top of the strut to replace the springs using a spring compressor.
You need to search this stuff on your own. The Suspension section is riddled with this very same question. If you can't find the procedure on here, go out and drop $25 on a Haynes/Chiltons manual.
Old 05-13-2008 | 07:08 PM
finch13's Avatar
And for bushings, there are three in the rear and three in front, but there's a lot more work involved in replacing them, you don't just pop 'em in.
hawaiian5
06-03-2007 01:28 PM
92halx
01-12-2007 01:07 AM
92halx
01-07-2007 01:07 AM
ivrex
11-21-2006 12:34 PM
msmi11
11-07-2006 12:09 AM
