Tapping Noise
Tapping Noise
Ok I have searched but can not find exactly what is going on.
The car has been flawless until recently and now it is just a tapping noise when I have to brake somewhat hard from freeway speeds.
The list of items that have been replaced or checked:
Front engine mount - replaced all others checked ok
Upper and lower control arms - replaced
Brake calipers, shoes and rotors checked tight and ok. although I noticed that the drivers side screws are missing on the rotor. All the rotors and pads are being replaced next week. Just noticed they are below specs.
Ball joints and swaybars tight and rubber stills seems soft.
Muffler tight and in all the gromets.
Subframe bolts there and tight.
I have had 12 years of flawless driving and the engine still starts and runs like new. it is this annoying noise that I am wanting to get to just incase it is something that is serious.
So now I am out of things to try and any help would be greatly appreciated.
Thanks in advance for the info.
Noises are never fun over the net....your "tapping" is my thump, someone else it is a clunk.
Have you looked at/inspected the strut rod bushings? This is the rod that goes from the lower control arm to the "beam" under the radiator.
Derekhhh
10-13-2013 04:14 PM
