17 or 18 inch wheels which will ride better**
RE: 17 or 18 inch wheels which will ride better
17" will technically ride better but I would doubt that you will notice a difference.
215 50 R 17 or 215 45 R 18 are as close to stock as you are going to get.
http://www.miata.net/garage/tirecalc.html
Your Best ride and also your Safest Ride is going to be on 17's. This is A+2 up sizeing which is more than enough. It will give you much Quicker cornering response than you will be used too and with the Larger Contact patch of your tires a more secure feeling when your stopping.
You should be lookin @ a 17X7" rim and a set of 215/50/17" tires...dont forget to get it aligned when those tires go on your ride...
**Sorry about that, but I had a bunch of calls to make and was not looking at any post's for awhile..**
If you have the 4cyl with the 4 lug wheels then you could use 35-45 mm offset.
If you have the 6cyl with the 5 lug wheels then you can use the 42-52 mm offset.
By the way...if your prone to not listen good and want to really go to [sm=bling.gif] then let's put you into these...which will fit..but you take your chances on control and Rapid Wear Out of your Tires....19X7.5 rims with 223/35/19" rubber..
[IMG]local://upfiles/22/826187EC3E0E4398B2C60766FA0254A9.jpg[/IMG]
ORIGINAL: newaccord99
cool thanks for the info im looking now for wheels...what OFFSET should i be lookiong for?
Which wheels did you find 17, 18 or 19 inch???
I have the V6 i foundsome wheels i like but they are +35 OFFSET those will not fit ??
nah forget that let's put some of these on there
http://paultan.org/archives/2006/04/...-bling-wheels/
THOSE WILL BE THE CORRECT WHEELS AND OFFSETS FOR YOUR CAR...
what brand of rim did you see that you'd like to buy?
WheelBrokerAng...
WheelBrokerAng...
they are 17" is there a difference on offset that will work on the car if they are 17 or 18"
the ones im looking at are 17" and 35 offset
