19" Wheels question
Old 07-23-2007 | 12:55 AM
joe3024's Avatar
Default 19" Wheels question
Looking for 19" for a 2005 accord someone offered me a great deal on a set but not sure if they will fit or if they would look horrible. They are 19" axis pentas of a g35 sedan tire size 245/40/19 someone let me know thanks. think offset is 35
Old 07-23-2007 | 01:52 AM
HuYnHness's Avatar
Default RE: 19" Wheels question
i realy dont know about tire width and all but i do know that ppl have fit 20" rims on this generation accord i think 19" is the perfect size if you like big rims i think the 20" on the accord looks really tacky only thing i wouldnt want 19" is the cost of tires
Old 07-23-2007 | 10:51 AM
joe3024's Avatar
thanks any little input helps
Old 07-23-2007 | 03:36 PM
smaglik's Avatar
19" tires are very expensive....at least 150/tire...300+ if you step into more performance
Old 07-23-2007 | 09:24 PM
Boostedv6's Avatar
For my 19" RacingHart, I'm using 215/35/19...with offset 42.
For your 245/40/19, off a G35, that seems rather high and a bit too wide.
For our Accords, we should be using 235/35/19. Gives you enough clearance if lowered, plus the width is perfect to match the sides.
Also, offset 35 seems ok...
We just installed Axis Penta on 06 TL, with 235/35/19 Toyo T1R and they look perfectly flush to the panels.
Sounds like the 245/40/19 are for a sedan, no?
But definitely for Accords, 235/35/19 are the way to go.
FYI, if 20"...then you go with 235/30/20.
Old 07-24-2007 | 02:17 PM
joe3024's Avatar
thanks for all the info the only reason why im asking is because they would only be a grand with tires from someone i know and i cant beat it
Old 07-27-2007 | 06:14 PM
bevans
you can get 19" tires from tire rack for $114.00, you can also buy a brand new set of 19" wheels off ebay for $480.00 shipped. check out all your options before dropping a grand.
Old 08-03-2007 | 01:48 PM
joe3024's Avatar
was wondering what is the stock offset for the 05 accord and what options do i have to play with other offset
StrikingAccord
05-15-2011 04:25 PM
StrikingAccord
07-06-2010 12:41 AM
Sweagle02
09-07-2009 11:42 AM
Sweagle02
02-05-2009 02:38 PM
starbai
08-27-2008 09:26 PM
