1993 10th Anniversary Tire Size?
Old 01-05-2009 | 11:31 AM
hatzipri's Avatar
Default 1993 10th Anniversary Tire Size?
Hey everyone, I was wondering if one of you could help me out. I have a set of 1993 Honda Accord 10th Anniversary Edition rims, and I wanted to put some tires on it, except I am not sure of the tire size. I have done some research, and all I have been able to determine is that it is basically the same tire size as the EX rim? Is this correct?
That means I can buy 195/60-15 tires and I would be okay?
Thanks for any help and time.
Old 01-05-2009 | 12:34 PM
finch13's Avatar
Default RE: 1993 10th Anniversary Tire Size?
The width of the tire is all that really matters, the other dimensions should work out to match the profile of stock tire on your car...
Basically, yes a 195mm wide tire will work, you can measure the width of the rim to double check and the rim dimensions (i.e. 17x7JJ) should be molded on the inside or back of the wheel somewhere.
Old 01-05-2009 | 07:08 PM
hatzipri's Avatar
So would I be able to put a 205/60/15 tire on the rim? Am I completely restricted to 195 for the width? I know I have seen some people put a wider tire on the rim than normal.
Thanks again for replying.
Anse
05-18-2023 09:05 PM
Thehunte199
05-03-2010 10:54 PM
hatzipri
11-29-2008 11:05 PM
mx4life
11-29-2008 10:28 PM
hatzipri
07-10-2008 01:22 AM
