20" on my 07 Accord
20" on my 07 Accord
ok need some suggestion if this would fit right or not.
Im going with these rims.
20x8.50"
40
5x112mm
tire size? 245/35/20 or 225/35/20? which would be smoother?
they told me if you go high offset there would be no rubbing even if you had passengers in the back seat.
Dfinately puttin a camber kit as well
My car coloris graphite pearl.
Also thinking about dropping it maybe 1 inch.
[IMG]local://upfiles/9186/335D4BF505814F3EB736DF9B13183B66.jpg[/IMG]
20x8.50"
40
5x112mm
RE: 20" on my 07 Accord
As with the tire size, go with the 245, I just switched out from the 225 and it is definitely a difference in smoothness. Good choice on the dubs those wheels looks sweet......
ThanksI have been looking for something to match my car for a while now and i found these rims and i fell in love with them. I am definately going with the 245 then.. the only difference i have compared to you is that i live in pothole central....
Since he is in "pothole central" then he isn't going to want to spend all that money on wheels and then get them dented up while driving home, the 245 is his best bet. If he is going to drop it I have measured mine and there is still and 1 3/4" of gap between the top of my tire and the fenderwell lip stock height. Ifhe goes with a mild drop then it he will be still be clear of everything......
I have BFGoodrichon mine and they are quiet and ride awesome, a little pricey in the beginning but they are worth it, I ordered them from Tire Rack. http://www.tirerack.com/tires/tires....s&place=10
