2003 OEM rim fit with 215/50R16?
Old 10-22-2009 | 06:15 PM
Zusue's Avatar
Default 2003 OEM rim fit with 215/50R16?
Hi all,
I am looking for a new set of tires for 2003 4dr Accord. I want to buy low profile tire with the OEM rim. is it possible? e.g. 215/50R16 90V or 205/50R16 87W
Thanks
Zusue
Old 10-22-2009 | 06:25 PM
finch13's Avatar
And the purpose would be? Sticking with the stock size keeps your speedometer accurate, your ride height the same, and your handling the same. If you want a lower profile (more than stepping down 5%), pick up some bigger wheels.
Plus, that 87 load rating is too low for your car.
Old 10-23-2009 | 01:06 PM
Zusue's Avatar
Thx. Probably I will stay with the OEM spec.
Old 11-17-2009 | 02:13 AM
Exclamation
Originally Posted by Zusue
Hi all,
Thanks
Zusue
205/65/15 is as big as you would go with those stock rims...
Old 11-17-2009 | 11:54 AM
Zusue's Avatar
For winter tires, I put on my set of steel rims with 205/65/15. Did you mean I can put 205/65/15 tires to stock rims? I thought my stock rims are 16".
Old 11-17-2009 | 12:43 PM
2003 Accord came with different stock size wheels.
LX = 15" steelies with 205/65-R15 tires & plastic wheel covers.
Different versions (EX, V-6, etc) came with (I think) either 15" aluminum or 16" aluminum, depending on other options or versions.
You can not put 15" tires onto 16" rims.
Old 11-17-2009 | 04:24 PM
Exclamation More Sizes
The 2003 Accords had 3 OEM wheel sizes, so I guess it depended on what came on your car as OEM or what may have been switched out at the dealer...OEM sizes were 15" 16" & 17"
Andrew James
06-21-2021 11:58 AM
vics_sharma
07-04-2010 08:55 PM
DavyDavon
09-14-2009 11:22 AM
w2f4
11-19-2008 12:25 PM
jclane
05-30-2008 12:05 PM
