Acura RL wheels?
RE: Acura RL wheels?
I'm not 100% sure on the size, you can use a tire size calculator (top post in wheels/tires section) and see what the speed/size difference is... the bolt pattern should be the same but I'd double check it to make sure... So: It should work but double check it for yourself online, www.1010tires.com has calculators and such...
You got me curious... and vintageant is pretty much right (minus what I would assume is a small typo) but you have a 4 x 114.3 pattern and the RL is 5 x 120 so, no dice.... I was not aware that acura switched to a 5 lug rim...
No, not a typo. My 2003 is 5 x 114.3, so I assumed 2001 was the same. I didn't realize that 2001's were 4 bolt. Apologies for misdirection!
This explains bolt patterns: http://www.rsracing.com/tech-wheel.html
RE: Acura RL wheels? UpDate!
ORIGINAL: vintageant
I'm pretty certain your bolt pattern is 5 x 114.3 and the Acura RL bolt pattern is 5 x 120, so doubt that they will fit.
Here is an up date for you all on the 2006 Acura RL's wheel size.
The stock wheels on this car are 17"x8" with a bolt pattern of
5 lugs on 115mm and by the way the OEM wheels run as high as
$550.00 each and their made by Asahi Mfg company who makes custom wheels also..
[IMG]local://upfiles/22/AE9BEC6692DF4811BCC4360FB63560D3.gif[/IMG]
StrikingAccord
05-15-2011 04:25 PM
StrikingAccord
07-06-2010 12:41 AM
